Old Furnace Fan Blowintg 24/7. Wiring Question. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 05:16 PM   #1
Rewards Points: 12
Old furnace fan blowintg 24/7. Wiring question.
I have a Gaffers and Sattler U80-1 gas furnace circa 1974 that blows all the time. I think the termostat portion is OK. The only way I can get it to stop is to unplug it (the furnace) from 110vac.
I looked at the wiring and the transformer is outputting 28VAC and it's got 24v written on it so I assume that's OK. I checked the thermostat with a meter and the relay is working OK. It's a 2-wire thermostat, powered by AA batteries (which are now brand new). So I think something on the other side of the transformer is closed when it should be open.
I'm just guessing here but I think the thermostat controls only the flame and some other sensor turns the blower on/off (see diagram).
There is a big two-wire switch of some kind or other that is closed. It has a screw adjustment for voltage (I assume) marked 80-90-100 ... 120-FAN OFF. What is this? There are also two wires going into the guts that I have not had a chance to measure, but imagine they might be the culprit? Any recommendations? The gas is still on (pilot only), so should I kill that before proceeding? I have a DMM. Thanks!!
grantb5 is offline   Reply With Quote
Old 09-09-2011, 05:19 PM   #2
Does the stat have rc and rh terminals?
Dr.HVAC is offline   Reply With Quote
Old 09-09-2011, 05:24 PM   #3
JJboy's Avatar
Check your thermostat
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-09-2011, 05:28 PM   #4
Rewards Points: 12
Switch in question..
Old 09-09-2011, 05:31 PM   #5
JJboy's Avatar
can you post a picture with an overview
Old 09-09-2011, 05:33 PM   #6
Rewards Points: 12
I think the thermostat is OK. It doesn't control the fan anyway and the flame is not going other than pilot (I think) ... though maybe I should double check that ;-)
Old 09-09-2011, 05:41 PM   #7
JJboy's Avatar
Sounds like the fan switch is close all the time.
Old 09-09-2011, 05:45 PM   #8
Agreed. Something that vintage wouldn't have a battery stat, the g circuit (or even full on) can happen by not splitting r circuits. I've also seen g tied into an r at the unit to allow not running a 3 wire to the stat, which produces that same result.
Old 09-09-2011, 05:45 PM   #9
Rewards Points: 12
Is the fan switch the blue thing? Where do I get a replacement? What are the other two wires that disappear into the guts (you can see them in the 2nd photo in front of the blue thing).
Another question, the blower motor is quite noisy. Are replacements easy to come by?
Old 09-09-2011, 05:47 PM   #10
That looks like some odd style of fan/limit I think?
Old 09-09-2011, 05:51 PM   #11
It still should be verified first that there is a separation of heat to fan modes. With two wires to the stat the fan only will come on for a call for heat. Make sure that only wires are where they should be and nothing is bypassed.
Next, you will need to reset your limit fan thing there to open only when the appropriate temp is reached (I'm pretty sure that's what "the blue thing" is)
Lastly, check the capacitor and confirm the motor doesn't need to be lubricated
Old 09-09-2011, 05:55 PM   #12
JJboy's Avatar
You have only 2 wires on Fan SW....one goes to motor and the another wire to L1.
Old 09-09-2011, 06:00 PM   #13
Rewards Points: 12
Maybe this part?
http://www.americanhvacparts.com/Mer...Code=FAN680201
Old 09-09-2011, 06:17 PM   #14
JJboy's Avatar
Yes, To be sure disconnect the two wires and do a test ..... if it shows 0 ohms between the 2 wires you have to replace it.
Old 09-09-2011, 07:37 PM   #15
REP
Nice find Grant,The part number is right there 40T3.
Just make sure you install it with the instructions because that line also feeds the transformer.
REP is offline   Reply With Quote
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Question about light in furnace rm Sherpa Electrical 7 12-22-2008 07:10 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
