Old Furnace With Bizarre Filter Setup - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 02:29 PM   #1
old furnace with bizarre filter setup
Hello,
I just moved into an older home that had extensive renovations, but the furnace is quite old. I went down to change the furnace filter, and I was surprised what I saw.. refer to the attached diagram (basically saw two 15x20 filters taped together and not actually on the the metal meant to support them).
I then found out that getting 15x20 filters is difficult: they seem to be very uncommon (not at home depot in any brand/style etc). So i figured the easiest/cheapest thing to do would be to convert the slots to fit a more common size.. (i had in mind 14x20 since the metal railings would support it with minor tweaking). I went out and bought a bunch of filters (was out of town and there was a fantastic sale - 3m filtrete micro allergy). This represents idea #1.
I later started thinking about the reason why they would setup the furnace in such a way (something i should have thought of earlier).. and figured it is probably an airflow thing (more surface area.. more air flow). THEN I read that the filtrete filters are considered crap by some hvac people because of airflow. So then I started thinking about doing idea #2...
I basically have 3 questions:
1. I was hoping to save money by using one filter at a time and changing it out as needed (originally thinking along 3m's recommendations of 3 months). If I used idea #2, would I need to change out the filters less often then idea #1?
2. If I use idea #2 then would I get more airflow (and less stress on the system)?
3. Why would they (the maker of the furnace) make such a setup?
Recommendations? Keep in mind that I don't want to toss the 10 filters I already bought. Please excuse my grade 3 level paint skills. Thanks for any help!
utek is offline   Reply With Quote
Old 11-14-2010, 03:52 PM   #2
HVAC / Plumbing
I see no problem with Idea 2 or 3.. Filter replacment depend on how dusty / your filter gets 1mo 2mo 3mo etc. Doesn't matter what the filter says
kenmac is offline   Reply With Quote
Old 10-14-2013, 08:49 PM   #3
Rewards Points: 150
delete
hpyjack2013 is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
filter in concord 80 plus furnace hyyx632 HVAC 5 12-12-2008 10:21 PM
Wet furnace filter ??? dc4nomore Appliances 10 11-10-2008 12:24 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
