Old Condenser Fan OK With New Compressor? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 12:45 AM   #1
Old condenser fan OK with new compressor?
12 year old unit, just had compressor replaced. Condenser fan is original, but works fine. Is there a big risk in continuing to use the condenser fan until it goes out?
If the fan stops, the thermal overload will trip and stop the compressor from burning up. But does it still overheat enough to significantly reduce the life of the compressor?
Thanks for your help.
Dan Parrish is offline   Reply With Quote
Old 05-26-2009, 07:01 AM   #2
HVAC / Plumbing
depends on the condition of the fan.. I have seen the rivets break / work loose causing the blades to eat up the condenser coils.. This would be bad just after a new comp. install
kenmac is offline   Reply With Quote
Old 05-26-2009, 07:31 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
If it stops, the compressor may start blowing its internal relief valve. That sounds like a shotgun blast and can harm the compressor.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor died, can it be replaced DIY? Firecracker HVAC 11 09-01-2008 08:41 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Help! Condenser fan comes on but compressor doesn''t ssporty21228 HVAC 2 07-21-2008 12:37 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
