Old A/c Unit Tied Into New Furnace...any Problems? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 07:14 PM   #1
Rewards Points: 160
Old A/c unit tied into new furnace...any problems?
Instead of paying 4 grand for a a/c unit which I can't afford, I tied my $400.00 in the door a/c unit into my cold air return. I have the a/c unit in a basement window and I am running fan only on my trane xr95 high eff furnace.
It is bowing cold air around the house and works good.
Any way that I am gonna screw up my furnace or furnace fan?
Just checking if I may be making a bad decision?
Thanks!
hellothere123 is offline   Reply With Quote
Old 06-18-2011, 07:18 PM   #2
An old Tradesmen
Rewards Points: 6,112
Will cause condensation inside the heat exchanger and rust it out from he inside out.
Old 06-18-2011, 11:13 PM   #3
Rewards Points: 160
I agree
After running it for one day I got a ton of condensation from the piping...it won't work...ah nice wasted day!
Old 06-19-2011, 12:29 AM   #4
An old Tradesmen
But at least you found out before it harmed your furnace permanently.
Old 06-19-2011, 09:56 AM   #5
Rewards Points: 160
That is definetly a positive.
I wired from G on the furnace to G on the thermostat. Now I can turn the fan on or off - to act like a summer fan. I cut in 2 cold air returns in the basement, one on either end of the return.
Would that cause any problems I'm unaware of?
Also I am not sure about the thermostat, I have heard that this may be a multistage fan and that I should get a thermostat that can run the fan at different speeds?
And thirdly, is there any way to have the "summer fan" I wired in - have it kick in at a certain tempurature or certain time of day...then I wouldn't have to wake up and manually turn the summer fan on.
Thanks!
Old 06-19-2011, 01:13 PM   #6
An old Tradesmen
Depends how cold the air is coming into the furnace.
Multispeed fans aren't controlled by the thermostat as far as what speed they use.
Thanks!
Would need a timer to do it.
Old 06-19-2011, 03:30 PM   #7
Rewards Points: 160
Cool
The cold air i assume is coming from 2 pipes tehy drilled to the outside of the house, the cold air returns I cut in are to allow basement air to circulate to the upstairs.
I have read about the Honeywell 8000 series thermostat that allowes you to set the fan speed to auto or on at certain times during the day...I was thinking of buying this and then setting the fan only to run in the morning to cool off the house before we get up.
Thanks for your info as I am a beginner on most of this HVAC stuff!
Old 06-19-2011, 04:00 PM   #8
An old Tradesmen
That stat doesn't control fan speed. It can be set to On, Auto, or Circ. Circ wil bring the fan on every 36 minutes if it has done a heat or cool call in that time period.
The humid air in the combustion intake pipe is what will condensate in the furnace heat exchanger.
Old 06-20-2011, 01:15 AM   #9
Rewards Points: 160
I'm not sure what pipe you mean? Is this the pipe that comes from outside?
I don't see how circulating colder air from the basement would cause any condensation or troubles, just moving air around right?
Old 06-20-2011, 01:20 AM   #10
An old Tradesmen
If your furnace has 2 PVC pipes going outside. One is the combustion air intake, the other is the exhaust.
How cold is the basement?
Old 06-20-2011, 01:47 AM   #11
Rewards Points: 160
basement is just cool, not cold...but when I run the fan it circulates the air and the upstairs is definetly a lot nicer!
Old 06-20-2011, 05:06 AM   #12
An old Tradesmen
Ok, should not be a problem them.
Lennox Furnace problems boolean HVAC 21 11-19-2012 07:45 PM
furnace problems poff HVAC 4 01-06-2011 04:57 AM
furnace problems taffyapple2 HVAC 5 12-14-2010 08:19 PM
coleman furnace blower motor problems coleman7970-856 HVAC 3 11-27-2010 07:51 PM
Problems With Gas Valve-Old Iron Core Furnace HAVCN HVAC 6 03-02-2009 05:52 PM
