Old A/C Unit- H20 Overflow Leakage Rusted - HVAC - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 09:04 AM   #1
Old A/C Unit- H20 overflow leakage rusted
Our A/C unit is over 40 years old. The pipes are rusted. The pan beneath the unit is leaking and overflowing with water. The 4x4 boards hoasting the unit up is soaked. Trying to tilt the unit by 1 centimeter so that water redirected itself into the pan and pipes worsened the problem. The ceiling doors to bedrooms and hallways are dripping everytime the ac is on. Instead of being charged $100 for advice or $6,000 for repairs is there another way to replace old parts of the still-usuable A/C unit?
johnsojt is offline   Reply With Quote
Old 07-23-2010, 12:13 PM   #2
Rewards Points: 77
One has to respect the $100 hesitancy in the face of dripping doors. I mean, the A/C is only 40 y/o. It ought to have been good for another 40, at least. Jeez, they don't make 'em like they used to.
Presumably there is a pipe exiting the coil which normally carries the condensate. It may have become stopped up. Also, the drain pan should have its own drainage pipe and/or a floating cut-off switch, so that it won't overflow.
tima2381 is offline   Reply With Quote
Old 07-23-2010, 04:20 PM   #3
An old Tradesmen
Rewards Points: 7,278
40 years ago, they didn't have float switches for that.
The drain pan is probably rusted out.
Might have to take it to a fabrication shop to have another one made. Since no new pans are made for it.
And then replace those rusted parts. And install the proper safeties.
Old 07-23-2010, 04:55 PM   #4
Rewards Points: 77
If the drain pan is "overflowing with water", it would seem there's another problem in addition to it maybe having "rusted out", right? I mean, there shouldn't be any water in the drain pan, should there?
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
