Old 01-23-2009, 02:28 PM   #16
JohnH1's Avatar
Originally Posted by adman77 View Post
You guys think i should try a seperate wire connecting from the circuit box directly to the furnace box?
To rule out this leak of any kind?
What do furnaces use anyways? 15amp 20?
12 gauge wire or 14?
There is no such thing as a voltage leak. They were giving you a line because they don't know what they are doing.
Did you try to jump the R to W? You can remove the T-stat and do it there if you feel more comfortable. We need to start with the basics before we go any deeper.
JohnH1 is offline   Reply With Quote
Old 01-23-2009, 02:42 PM   #17
Hey ya John
I agree with ya on that.
I will jump the wires tonight,see if i can get a spark or click or anything atleast.
I will update later tomorrow
Thanks again for your help.
adman77 is offline   Reply With Quote
Old 01-23-2009, 03:09 PM   #18
hvaclover's Avatar
There is a phenomena called voltage leakage. And in a overtly technical examination of the furnace fault, it could be used to describe the furnace fault.
However it does go above and beyond the normal tech jargon one would use when explaining a furnace problem to a HO.
http://en.wikipedia.org/wiki/Subthreshold_leakage
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-23-2009, 03:50 PM   #19
JohnH1's Avatar
I guess the repair guys could have been electronics experts. But since they walked away with a basicly Uhh I duno I dout they were. Now I myself couldent walk away. I have to figure it out or it will keep me awake at night. It would make me nuts not to figure something out! I guess that why some of us find our way to thes sites. We just have to keep thinking and figuring things out. It feels good to solve problems.
Old 01-23-2009, 07:39 PM   #20
Dr Heat's Avatar
you should only as a test. 15 amp 14ga is fine
Not to rule out the "Leak" but if you dropped neutral or reversed polarity
Dr Heat is offline   Reply With Quote
Old 01-29-2009, 11:56 PM   #21
OKay
Here is what i had done.
I ran a direct line from the circuit box to the furnace wire.
I had jumped the thermostat Red and white wire.
After powering the unit back on and having the t-stat set to auto.
Nothing happened.
The only thing i had seen,which i dont know if it has shown up before, on the t-stat. When i switch to auto" error" comes up.
But when i set the furnace to the " on" position, it blows out cold air and no error comes up.
I had even reset the t-stat and when i set it from off to auto, it took a few seconds then error came back up.
Just says " error "
I did not see or hear anything come on or light , not even a click, which i thought normally would happen.
Anyone know what the next step would be to try?
Old 01-30-2009, 06:09 PM   #22
Let me know what you think i can do next Guys.
Its cold out here in the North east.
Old 01-30-2009, 06:33 PM   #23
JohnH1's Avatar
I would take the thermostat out of the equation. Disconect it compleatly from the furnace and jump only the r & w at the furnace. Also make sure you have hot and ground correct if they are reversed it may not operate.
Old 01-30-2009, 07:12 PM   #24
HI
Okay, i had disconnected all thermostat wires from the furnaces circuit board.
A red,white and green wire.
Am i jumping the red and white thermostat wires itself?
If so, that is what i had done before.
If you are refering to another red and white wire somewhere on the furnace, i may need some more help on choosing which ones.
Old 01-30-2009, 07:20 PM   #25
JohnH1's Avatar
The r and w termemols on the furnace itself were the thermostat connects to the furnace
Old 01-30-2009, 07:47 PM   #26
OKay,this is what i tried.
I had jumped the t-stat wires on the circuit board.
The furnace blower came on for about 2 seconds then stopped and that was that.i could not get it to repeat that again.even unplugged power and all that.
Old 01-30-2009, 07:52 PM   #27
hvaclover's Avatar
If you didn't disconnect the white and red wire at the board you blew the stat.
Old 01-30-2009, 08:10 PM   #28
Yikes.I blew my stat?
I just checked it, it has a little fuse in it,looks okay.
I have one of those electronic t-stats
I had put the cover back on and reconnected the red and white wires back to the circuit board.
What can i do next?
Old 01-30-2009, 08:21 PM   #29
hvaclover's Avatar
Be the first stat I ever saw with a fuse.
What kind do you have?
Old 01-30-2009, 08:25 PM   #30
its a robertshaw 9600 digital tstat
More On This Topic
Next, let me show you what you need to do. Take this ingot, which is a blended lead alloy, lower this into the furnace, which already has molten lead in there, and let it mix within the lead. Be mindful of the temperature that you have this on. You don... Read More »
Hi! I’m William Myers with Subaru for Expert Village. We’ve checked your battery level, now if you had to add water to your battery all you would do is remove the cap and add your distilled water right in there. That’s how you would add... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Now, I'm going to put some Payne?s gray down in here. And this is partially to balance this set of trees. That is, value wise. It's dark and we need something over here that's pretty dark too. Read More »
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 08:10 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Bryant Plus 90 start up problem mgraw HVAC 2 01-07-2008 07:54 PM
Problem with Payne ultra 90 Mark H HVAC 19 12-31-2007 10:25 PM
Furance Problem molly_38 General Discussion 3 11-11-2006 04:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
