Old AC Plumbing Advice - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 09:35 PM   #1
Rewards Points: 91
Old AC Plumbing advice
My AC/Furnace is working fine however I was wondering what I could do to fix this weird setup I have. THe furnace pulls air from above the unit and forces the air down into the ducts that are insulated and under the crawlspace of my home. Here is pics however of the plumbing of it. The Coolant lines and Condensation like exit through down through the insulation and out of the house, but there is also this strange 3inch pipe that sits next to it. I have the backup condensation hose sitting in that, but the pipe just goes through the insulation and sits in my crawlspace.
I was thinking that wouldn't the air from the blower draw from under the house as well as the intake vent?
And also is it ok for there to be an opening in the door of the furnace where the handle would be?
no_Wedge is offline   Reply With Quote
Old 07-12-2013, 01:10 PM   #2
Rewards Points: 91
any advice on how to seal this, or if it would be a problem?
Old 07-12-2013, 07:35 PM   #3
biggles's Avatar
is there AIR sucking over or blowing out over those pipes pack insulation in there..if your sucking air then that temp is mixing with the house return and adding a false load...blowing out cool your losing air up into the house...hope this helps. where is this air handler ...attic... crawlspace..closet??? that looks scary in there
Old 07-13-2013, 02:10 PM   #4
Rewards Points: 91
it's just in the utility room, return air pulls from above the unit and is forced down to the ducts, but I was concerned it may also be pulling from the hole in the bottom of the unit. Would packing insulation and duct taping over this suffice?
Old 07-13-2013, 03:08 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
YES, buy some of the LOW expanding 3M spray foam insulation from HDepot in the caulking, window repair and weather stripping dept. and carefully spray it in. The high expanding stuff will make a huge mess and is for large areas.
The Following User Says Thank You to yuri For This Useful Post:
COLDIRON (07-15-2013)
Old 07-13-2013, 04:29 PM   #6
Rewards Points: 91
roger that i'll use the extra for my dogs house. anyone know how to reuse that stuff. I've tried unsucessfully many time to be able to reuse an old can.
Old 07-13-2013, 04:42 PM   #7
The cans are a one-usage situation...unless you purchase a foam gun
RoyalAcresRod is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
Advice on plumbing two water heaters in series TLockwood Plumbing 7 01-10-2012 09:01 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
