Is It Ok To Put 2 Vents On One Duct? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 05:40 PM   #1
Is it ok to put 2 vents on one duct?
I need to heat 2 rooms with 1 duct. The vent to the living room is about 6 feet off the floor and I was going to put one in the bedroom just off the baseboard. Is it alright to do it this way?
vetting is offline   Reply With Quote
Old 02-04-2009, 06:06 PM   #2
An old Tradesmen
Rewards Points: 6,876
Doubtfull its big enough to handle both rooms.
Old 02-04-2009, 07:04 PM   #3
It overheats the living room as is...so as long as it not a problem, its more than enough heat coming out.
Old 02-05-2009, 05:40 AM   #4
An old Tradesmen
You can do it.
But, been to a lot of places that said teh same thing. The run use to over heat the single room it served. But, once it was piped to a second room also. It wasn't enough for both rooms.
Try it, if it works, fine. If not, you end up putting in a second run anyway.
Removing some vents rdmccaw HVAC 4 10-22-2008 01:00 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 05:02 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
