Is It Ok To Drain Condensate To A Below Slab Interior Perimeter Drain? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 04:56 PM   #1
steveel's Avatar
is it ok to drain condensate to a below slab interior perimeter drain?
our only convenient place to run condensate drain lines for high-efficiency gas appliances will be into a below-slab interior perimeter drain I'm also installing. The thought is to leave a PVC stub when we repour the slab, and just clip the drain lines into that stub.
Otherwise, the city has blessed the perimeter drain and sump plan. Any technical problem running the condensate to that drain this way?
steveel is offline   Reply With Quote
Old 12-03-2010, 04:57 PM   #2
Civil Engineer
Rewards Points: 4,854
The copndensate from your furnace will be effectively pure water, so it can certainly be drained into the perimeter drain, assuming your town permits it.
Old 12-03-2010, 05:20 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 116
Actually it is not pure. It is slightly acidic (like orange juice). Most cities don't mind it anymore in sewer drains as laundry soap is alkaline and the 2 neutralize each other ( I wuz told) but it does have some byproducts of combustion in it. Best to find out from the inspectors first. There used to be a neutralizer kit to put on the drain but you would have to find out from the furnace manufacturer. They were expensive and prone to plugging up and I would avoid them.
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Condensate Drain Pan Leak tbfreeland HVAC 0 09-01-2010 10:34 PM
HELP ASAP Relocating Shower Drain In Slab - Drain Pipe Loose perryj Plumbing 5 08-20-2010 08:48 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
New Drain for HVAC Condensate Pump LoveMyHome Plumbing 6 12-05-2009 06:59 AM
