Old 01-16-2008, 11:05 PM   #1
Oil tank whistler.
I had an oil company come out to fill my tank and I thought they did because they took my check and cashed it. But after checking my tank and finding out that it is now EMPTY I went back and double checked my bill. They had in very small writing on it that the oil couldn't be delivered because my whistler was not working. But I still paid for the oil... Hmmm... I guess a whole different story there.. But anyway, how hard is it to change one of these and where exactly is it in the vent line? Thanks.. Also approx price would help too....
Cadensdad is offline   Reply With Quote
Old 01-16-2008, 11:09 PM   #2
Union HVAC Tech.
Oil tank whistler.
It is a vent termination, the outer most fitting on the vent line. No idea what they cost.
bigMikeB is offline   Reply With Quote
Old 01-17-2008, 02:24 AM   #3
Oil tank whistler.
Thanks... I found a hvac shop. Local... I'll stop to see if I can just pick a new one up.
Old 01-17-2008, 07:15 AM   #4
Union HVAC Tech.
Oil tank whistler.
No problem.
Old 01-17-2008, 07:34 AM   #5
Master General ReEngineer
Bondo's Avatar
Oil tank whistler.
Hmmmmm,........
On Every single 1 I've ever seen,......
The Whistle is a part of the Vent/ Gauge that screws into the top of the Tank........
Nothing but a cover on the outside end of the vent line.......
Old 01-17-2008, 07:54 AM   #6
Oil tank whistler.
I just replaced mine this past summer. It screws into the tank then your vent line gets screwed to the whistler and vents outside.
I bought mine for 25$ from my oil delivery company.
It was fairly easy to put in. Just make sure you use pipe dope on the threads so you do not get any odors in your basement.
sandyman720 is offline   Reply With Quote
Old 01-18-2008, 06:14 PM   #7
Mainah's Avatar
Oil tank whistler.
save your money- just remove the vent cap outdoors and check for bees nest ect.. if thats clear try blowing hard through the vent pipe to send any blockage back into the tank, 9 outta 10 times this works like a charm-
if this doesn't work just unpipe it and clean it manualy-- there is nothing to "break" in a vent whistle - the the stem of the whistle gets plugged by insects or sludge
Mainah is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 12:33 PM
GFCI for a fish tank? fw2007 Electrical 6 10-05-2007 01:06 PM
