Oil Tank Gauge Stuck - How To Fix? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 08:13 AM   #1
Rewards Points: 93
Oil tank gauge stuck - How to fix?
Hi all,
On Sunday the oil tank gauge indicated 3/8 of a tank. Last night they filled up 477 liters (122 US gallons) on a 909 liter tank. After the fillup the gauge got stuck on 1/8 tank. I tried tapping it and giggling it and the tank and it won't go up (Should I drop a viagra in the tank ). It looks exatly like the on in the attached image.
I called back the oil company and they said it is common occurance. And that I shoudl remove the screws holding the gauge in place and pull it up and down (or something like that).
Any suggestions on how to make it work again?
thanks!
terry
tls1 is offline   Reply With Quote
Old 01-23-2013, 08:25 AM   #2
Rewards Points: 104
Yup, just like they said. Remove the 4 screws that hold the clear cover in place, take the red indicator between your thumb and forefinger, and move it up and down a bit. Don't force it, but just wiggle it a little bit if you need to, and it should go back to where it should be.
Old 01-23-2013, 08:33 AM   #3
Rewards Points: 93
Thanks! I'll try that!
Note that when I was tapping the plastic cover and giggling the tank, I did not that the needle was shaving left and right but not going up or down).
Is there a way to calibrate the gauge? It's was down to approx 1/2 tank of oil, but the gauge said 1/4.
Cheers!
Terry
Old 01-23-2013, 08:54 AM   #4
Roofmaster
Rewards Points: 2,210
I like the Viagra Idea Myself. Or you could simply use a wooden dowel with marks etched into it.
Old 01-23-2013, 08:56 AM   #5
Rewards Points: 93
I think a wooden dowel would hurt
better stick to viagra....
Old 01-23-2013, 09:27 AM   #6
Rewards Points: 104
Sounds like it must have been hanging up a bit beforehand. Free it up from the top, and see if that takes care of it. If not, loosen the base of the gauge with a pipe wrench or pair of adjustable pliers, unthread it, lift the whole gauge out, carefully so that you don't bend the rod, and clean it up. Could be just some gunk on it, or could be a hole in the float. Or could be the wrong gauge, unless you are sure that it did work right at some point. If necessary, your oil supplier should have new gauges, but Jagans suggestion works well too; just set an aluminum pie tin next to the tank, to stand the stick in, and no more hassles.
Old 01-23-2013, 05:20 PM   #7
Rewards Points: 93
Hi,
So I removed the 4 screws and removed the plastic cover. Ouf stinky stuff! I was able to move the red needle up and down manually...although it seems as though it was moving through thick liquid (the oil). I even pulled it far out (about 2 feet) of the hole and put it back several times. But then no matter where I put it (eg: 1/4 or 1/2 or 3/4) it did not move just sat there and did not adjust to the correct position (4/4).
Maybe it's gunked up. Do I keep pulling it complete out? A disk with 2 rods below come up.
Tank is made in 1989. Not sure if ever the gauge was replaced.
Thanks!
Terry
Old 01-23-2013, 05:51 PM   #8
An old Tradesmen
Rewards Points: 7,344
Unscrew entire gauge and install a new one.
Old 01-23-2013, 06:50 PM   #9
Rewards Points: 582
unscrew entire gauge that one has linkage and a float assy.. I think... have seen them get stuck worth a try to repair...if not replace it as bt suggest..ben sr
how to install oil tank vent whistle when vent pipe is welded to tank greenfieldja HVAC 4 12-10-2014 09:24 PM
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 04:51 PM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 04:16 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
