Oil Tank Fill And Vent Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 11:42 AM   #1
Oil tank fill and vent question
Adding a small bump-out (2’ x 5’x 8’ h) room to the outside of my house. However, my basement oil tank vent and fill are in the way. Want to add a 45 elbow and 24” to both so they will extend outside the new room.
Oil company told me all my piping was copper so it could not be extended, it all needed to be replaced with (2”) black pipe….$800 (5hrs labor @ $100 per hr + $300 in material)
Question –
Is there any code saying I can’t do this work myself?
Is there any cautions you would give me? (Besides no flames)
Dave
Davidb6 is offline   Reply With Quote
Old 01-28-2009, 11:49 AM   #2
An old Tradesmen
Rewards Points: 7,376
Pretty sure the code for the vent to be 2" was repealed.
Made it so that the fill whistle wouldn't always whistle when it was suppose to.
Check with your local ode enforcement office, if you need a permit.
Should be no restriction gainst you doing it.
But, if your oil company, doesn't like the way its done. They are allowed to refuse to fill your tank.
Old 01-28-2009, 01:02 PM   #3
Thanks.
Is the current code I should be looking at - NFPA 31
(http://www.kerrheating.com/TechInfo/...ank_guide.html)
These regulations show –
The fill pipe material shall be 2 in (50 mm) schedule 40 black steel pipe.
Vent pipe shall not be less than 1Ό in (30 mm) nominal diameter.
Air vent pipe with whistle alarm; install 2ft (600 mm) above fill pipe.
Old 01-28-2009, 02:47 PM   #4
An old Tradesmen
Yep, thats the one.
Old 01-30-2009, 07:44 AM   #5
Thanks beenthere, appreciate the help.
Basement oil tank fill and vent Davidb6 Plumbing 3 01-30-2009 06:02 PM
insulating between rafters - no ridge vent rtoni Building & Construction 3 01-30-2009 04:14 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Oil tank whistler. Cadensdad HVAC 6 01-18-2008 05:14 PM
Toilet Flushing ? Piney Plumbing 5 10-20-2007 01:56 PM
