Is Oil Smell Normal When Furnace Ignites? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2007, 08:51 PM   #1
Is oil smell normal when furnace ignites?
I had my cellar door open while I was upstairs on the main floor of my home and when the furnace kicked on, I smelled oil. Is this normal? I have not had my furnace serviced yet because I am on a very low budget and can't afford it yet.
skittlzski is offline   Reply With Quote
Old 11-20-2007, 08:25 PM   #2
I've never smelled oil from a furnace.... please follow up and let us know what it is.
sams7267 is offline   Reply With Quote
Old 11-22-2007, 06:59 AM   #3
coolmen's Avatar
you not familer with oil furnaces.
coolmen is offline   Reply With Quote
Old 11-22-2007, 07:00 AM   #4
coolmen's Avatar
your oil furnace needs to be serviced/cleaned. Why wait till it breaks down completly in the cold.
Old 11-22-2007, 09:01 AM   #5
Most of the time something is wrong when you smell oil, but on some older burners without oil solenoid valves, pre-purge and post purge you'll sometimes get a slight oil smell on start-up due to nozzle after-drip at the end of the previous cycle, especially when you have have delayed ignition, restriction through the heat exchanger or poor draft.
MarkJames is offline   Reply With Quote
Old 11-30-2007, 05:18 AM   #6
Yes, it is an older burner. Thanks, that is probably what it is. It does not smell of oil every time it ignites, just once in a while.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
