-   -   Is oil smell normal when furnace ignites? (http://www.diychatroom.com/f17/oil-smell-normal-when-furnace-ignites-13582/)
skittlzski 11-19-2007 08:51 PM
I had my cellar door open while I was upstairs on the main floor of my home and when the furnace kicked on, I smelled oil. Is this normal? I have not had my furnace serviced yet because I am on a very low budget and can't afford it yet.
sams7267 11-20-2007 08:25 PM
I've never smelled oil from a furnace.... please follow up and let us know what it is.
coolmen 11-22-2007 06:59 AM
you not familer with oil furnaces.
coolmen 11-22-2007 07:00 AM
your oil furnace needs to be serviced/cleaned. Why wait till it breaks down completly in the cold.
MarkJames 11-22-2007 09:01 AM
Most of the time something is wrong when you smell oil, but on some older burners without oil solenoid valves, pre-purge and post purge you'll sometimes get a slight oil smell on start-up due to nozzle after-drip at the end of the previous cycle, especially when you have have delayed ignition, restriction through the heat exchanger or poor draft.
skittlzski 11-30-2007 05:18 AM
Yes, it is an older burner. Thanks, that is probably what it is. It does not smell of oil every time it ignites, just once in a while.
