Oil Line Freezing - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 03:12 PM   #16
FClef's Avatar
Rewards Points: 160
Originally Posted by He123321 View Post
I had a similar problem this past winter but it was not my line freezing, but the tank. I was told that I have water, and sludge in it that is freezing on me. Its an old tank with the line coming off the bottom end. I was told that by relocating the line to the top, it would take care of the problem. Would relocating my line really help?
Absolutely. An above ground tank with a valve on the bottom is definitely more susceptible to freezing than one off the top. Valves off the bottom of outside tanks can be the cause of oil spills as well because either something hits the valve and cracks it or I have seen water freeze in there and crack the valve. It happens.
When the line is put in the top of the tank they should put the copper until it hits the bottom of the tank and then raise it about 2" from the bottom. This will help to not get water in the lines. The other thing that could be done at the same time is to have them run a second line to your burner which would basically make it a self-priming pump. I would highly recommend getting the second line installed because if the burner is running when you get an oil delivery with a single pipe from the top of the tank it can get airbound and you will need to prime the pump yourself.
You also should have a tank gauge and a vent installed. If you don't, then get one. I ran into a customer that was burning out fuel pumps on his heater. Turns out that there were no vents in the tank and it actually pulled the tank into a vacuum.
FClef is offline   Reply With Quote
The Following User Says Thank You to FClef For This Useful Post:
He123321 (05-18-2013)
Main Line Clog Master Brian Plumbing 46 09-06-2012 08:38 PM
5/8 water meter with a 1 inch servise line ????? ogoz23 Plumbing 11 02-04-2012 10:35 PM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 07:09 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
