Oil Heater, Pump Cavitating, What To Do? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 08:46 PM   #1
Rewards Points: 109
oil heater, pump cavitating, what to do?
I had to move the tank 3 feet further down towards ground. So, now the heater pump needs to pull fuel up 3 more feet. There was already a long distance from tank to pump. About 40 feet. The tank was at the same height as the pump. fuel got pulled up about 5 feet, over about 30, then down about 5 feet. Its been working like this for 26 years. However, I had to move tank down 3 feet. So, its now pulling up 8 feet, then over 30 feet, then down 5 feet. However, now it keeps cavitating. What to do? Last resort is to move the tank back up. Someone said a small low pressure automotive fuel pump mounted at the tank to push the fuel. This work?
tks,
paul
paulmars is offline   Reply With Quote
Old 02-18-2013, 08:49 PM   #2
Rewards Points: 109
sorry, central home heater, diesel fuel oil.
Looking for site listing of my email address, to make sure its right, However, cant find it anywhere. <Please don't put your email address in post.>
Moderator team.
Old 02-18-2013, 10:09 PM   #3
REP
To ans your question,no that won't work.Try running a return line from your pump to the tank and make sure the filter is replaced every year.
REP is offline   Reply With Quote
Old 02-19-2013, 05:19 AM   #4
An old Tradesmen
Rewards Points: 7,370
Length of line is too long. When the tank was at same height, the 5 foot up and 5 foot down canceled each other out.
As said by rep. Run a return lie. You'll need to add a bypass plug to the pump. Another way is to install a tiger loop at/near the burner.
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 05:15 PM
MasterCraft shallow well pump not happy rtoni Plumbing 7 06-06-2011 11:41 AM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
