Oil To Gas With Power Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2013, 02:38 PM   #1
Oil to gas with power vent
I have a smith series 8 oil boiler with a tjernlund ss1 power vent. I want to install a carlin ez gas burner. What will I need to do this conversion. someone told me I will need to change the controller. Is this correct and what controller for the burner, or the power vent.
Thank You
rbelli is offline   Reply With Quote
Old 12-15-2013, 02:47 PM   #2
An old Tradesmen
Rewards Points: 7,400
Nope, not correct. It will be able to work with your existing aquastat, and should work fine with your SS1.
Old 12-15-2013, 02:59 PM   #3
Thank You for the quick response. The Carlin EZ gas burner I am getting comes with a field control, it is a 60200FR microprocessor control. I believe there is an electronic damper that is included with the carlin ez gas unit, will I need this? I am totaly new to gas boilers, I grew up with oil only, so please excuse my ignorance
Old 12-15-2013, 03:25 PM   #4
An old Tradesmen
Don't recall a damper coming with them.
The 60200rf is a simple safety control. Easy to wire. Pretty much just like you would a primary on an oil burner.
Power gable vents VS ridege vent USNavychief Roofing/Siding 1 07-15-2011 09:35 AM
Do I need a power vent water heater? bw77 HVAC 1 06-20-2011 05:05 PM
Ridge Vent and Power Vent? etern33 Roofing/Siding 7 06-06-2011 07:06 AM
Ridge vent and power vent neikorott Roofing/Siding 1 09-09-2010 05:57 AM
Noise from boiler power vent den HVAC 2 03-03-2007 07:10 AM
