Oil To Gas Conversion W/ Wayne P265 & P250 Burners - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 08:11 PM   #1
Rewards Points: 156
oil to gas conversion w/ Wayne P265 & P250 burners
Does anyone have any experience in converting oil furnaces or boilers over from oil burners to gas? I came across this after just looking around and thought it would be a great option for my existing oil furnace, which is in great shape. The gas company will run the gas lines for free to my house if I use gas as my primary source of heat, so I would only need to foot the cost of the unit, and installation into the furnace.
http://www.waynecombustion.com/store/
av-geek is offline   Reply With Quote
Old 10-10-2012, 08:52 PM   #2
Rewards Points: 610
your existing furnace has to be rated for gas combustion...should be indicated on label as Input XXXXX? BTUH Natural Gas
If so, new burner, controls, piping/fittings inside house + CHA CHING!
Require new chimney liner to meet gas burning Code...CHA CHING!!
May need "field approval" from local gas inspector more cha ching?
Other costs I have likely not included .... more cha ching!
May be wisewr tio wait until you really need a new furnace before switching to gas OR at least go with new HI Efficiency condensing furnace SAVE$$$$
techpappy is offline   Reply With Quote
Old 10-10-2012, 10:17 PM   #3
Rewards Points: 156
Some of these expenses I would imagine would be needed anyways if I went with a entire new gas furnace anyways...like the gas plumbing from the meter to the furnace and the inspections. Would I need to get the flue lined if I was going with an entire new furnace too?
Old 10-10-2012, 10:25 PM   #4
Rewards Points: 610
no flue liner needed with hi efficiency condensing gas furnace ...it is directly vented outside via PVC piping AND should save you about 30 - 40% fuel costs!
NOTE..if gas supplier wants your business they should send experienced rep to let you know conversion possibilities and costs
Old 10-11-2012, 04:45 AM   #5
An old Tradesmen
Rewards Points: 6,944
You said your oil furnace is in good shape. How old is it.
Old 10-11-2012, 07:24 AM   #6
Rewards Points: 1,294
Just curious...how much do one of these replacement units cost?
danpik is offline   Reply With Quote
Old 10-11-2012, 05:34 PM   #7
An old Tradesmen
Don't know a price off the top of my head. but they are not cheap. They aren't anymore efficient then an oil burner. Its just that gas is cheaper right now, and probably will be for a few more years to come.
Old 10-12-2012, 09:02 AM   #8
Rewards Points: 610
In practical terms, AFUE i.e., Hi Eff condensing gas furnaces are at least 15% more efficient than oil and as has been said gas is a lot less expensive. AND less to maintain..oil tank alone is a PITA what with the freakin' insurance companies demanding replacenment as early as 10 years and not more than 20.
Furnace Burners Flicker On and Off EDOinHB HVAC 19 02-22-2012 05:55 PM
Furnace burners will shut off after 10 mins Liberator HVAC 10 01-20-2012 10:23 AM
Burners won't all light Vern Clanton HVAC 9 12-28-2011 04:38 PM
