Oil To Gas Conversion Information - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 06:55 PM   #31
Rewards Points: 610
OK so I,'m getting confused here...originally you said you got a price for a gas furnace of $1,000...but you actually have an oil fired BOILER..so,what did the 1,000 include...AND have we answered your questions...otherwise I am lost as to advise you..can we provide any more assistance
techpappy is offline   Reply With Quote
Old 09-29-2012, 06:58 PM   #32
Rewards Points: 190
$1,000 was just to purchase the furnace... Boiler terminology probably got mixed up...
ryanb4614 is offline   Reply With Quote
Old 09-29-2012, 07:24 PM   #33
Missouri Bound's Avatar
If you can get a gas boiler for $1000 you should make the investment. Can you do this work yourself?
Do you want it your way or the right way?
Old 09-29-2012, 10:44 PM   #34
Rewards Points: 156
If you are handy at soldering copper pipe, I would try and do it myself. Of course, you will also need some pieces/parts from your local plumbing supply shop like some elbows and some sections of pipe so that you can join the existing pipes to the new boiler. It looks much easier to install a boiler than a ducted furnace.
I am with the others here too...Install an electric water heater. If you are worried about the insert leaking after it's de-pressurized, just cap ONE end of the hot-water insert with a faucet, and leave the other side connected to the water line. There will still be water in it at line pressure. Of course, if you get a new boiler, you can simply order it without a hot-water insert and instead, go get you an electric water heater
av-geek is offline   Reply With Quote
Old 09-30-2012, 10:40 AM   #35
Rewards Points: 610
The OP just said that the $1,000 was for a furnace NOT a boiler so would require all new duct work as well.
Old 11-28-2012, 06:02 PM   #36
Rewards Points: 190
My boiler started leaking..... There is water coming out from under it not sure where exactly. I can't figure out how to get the jacket off to take a look. Called my oil guy to come and take a look. The maybe I will be converting sooner then anticipated.
Gas Valve 7200 IPER-S7C LP Conversion mikefrommi HVAC 5 03-06-2011 10:40 PM
Installing elevated wood floor in garage conversion. FWatty Flooring 0 02-22-2011 04:49 PM
Garage Conversion SDEngr Remodeling 13 06-01-2010 05:11 PM
You too can buy an AFCI breaker for $1000! Gigs Electrical 19 02-09-2009 04:13 PM
