Oil To Gas Conversion Information - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 03:00 PM   #16
Rewards Points: 610
ryanb..what is that box like unit in the stack/flue at back of boiler? Looks like a thermal heat exchanger that extracts excess heat from stack before gases are vented to chimney. Is it working. Does it help heat the air in the boiler room OR are there pipes running through it to preheat system water OR domestic Hot Water? Is there a fan on it. Is there a temperature controller on it. Does water circulate through it?
CURIOUS!
techpappy is offline   Reply With Quote
Old 09-28-2012, 03:05 PM   #17
Rewards Points: 610
looks pretty ancient...It's up to you but I wouldn't spend more than $2K on conversiion then you could have more problems so, On second thought..GO WITH HI EFF GAS NOW..if you can manage it. BIG SMILE WHEN YOU GET YOUR GAS BILL!
Old 09-28-2012, 03:13 PM   #18
An old Tradesmen
Rewards Points: 8,236
Unfortunately, by only getting 100 gallons at a time, you probably also pay a higher per gallon price for a short delivery.
Get an electric water heater, and stop using that tankless coil, and you can save yourself 200 plus gallons a year on oil.
Old 09-28-2012, 04:16 PM   #19
Rewards Points: 190
I always ask what the price is per gallon first. He doesn't up charge. Everyone around here is a 100 gal minimum. I was think of n electric water heater but then I was told it would ruin the gasket and it would leak.
ryanb4614 is offline   Reply With Quote
Old 09-28-2012, 08:15 PM   #20
Missouri Bound's Avatar
Originally Posted by ben's plumbing View Post
manual d for sizing of the new furnace....
A manual D for a boiler..
Do you want it your way or the right way?
Old 09-28-2012, 09:40 PM   #21
Rewards Points: 582
thougth they were talking about new furnace....missed the boiler part....getting old and can't read....thanks..
Old 09-28-2012, 09:44 PM   #22
You aren't the only one getting old....I'm surprised I caught it!
Old 09-28-2012, 09:46 PM   #23
Rewards Points: 582
say what
Old 09-29-2012, 04:25 AM   #24
An old Tradesmen
The boiler low limit can be set to only maintain 100 degree temp if your afraid of the gasket getting hard and cracking.
Old 09-29-2012, 08:50 AM   #25
Rewards Points: 610
Don't worry about gaskets..most boilers are "off" for the summer and don't have the problem. Should be OK as long as you don't drain the boiler and leave it empty for a long period of time.
Old 09-29-2012, 08:51 AM   #26
Rewards Points: 190
Is this something I can do. Or should I have a plumber.i can do electric and basic plumbing.
Old 09-29-2012, 08:54 AM   #27
An old Tradesmen
You can DIY.
Old 09-29-2012, 10:12 AM   #28
Rewards Points: 190
CURIOUS!
There is a switch on wired to it. It's basically a fan. It goes on once in awhile my guess is to heat the boiler room because the other side of the basement has baseboard heaters.
Old 09-29-2012, 10:13 AM   #29
Rewards Points: 190
This was installed in 1997. I would happy to get gas but I don't have $5000 for the installation.
Old 09-29-2012, 02:16 PM   #30
How long will it take you to spend $5000 on oil?
Gas Valve 7200 IPER-S7C LP Conversion mikefrommi HVAC 5 03-06-2011 09:40 PM
Installing elevated wood floor in garage conversion. FWatty Flooring 0 02-22-2011 03:49 PM
Garage Conversion SDEngr Remodeling 13 06-01-2010 04:11 PM
You too can buy an AFCI breaker for $1000! Gigs Electrical 19 02-09-2009 03:13 PM
