Oil Furnace / Wood Stove Chimney ?? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 06:25 PM   #1
wgi
I have a fuel oil furnace with a clay lined masonry chimney. I'l like to set a wood fired hot air funace along side of the oil furnace. Is there any reason I can't tie into the same chimney ahead of the thru wall thimble, but after the draft inducer on the output of the furnace? Would this cause any problems for either of the heat sources?
wgi is offline   Reply With Quote
Old 02-23-2008, 12:50 PM   #2
What size is the clay lining?
What diameter is the fuel oil vent pipe?
What size will the wood vent be?
Have you had the chimney inspected?
redline is offline   Reply With Quote
Old 02-23-2008, 02:46 PM   #3
I know a wood stove can't share a flue with any other source. I'm not sure if that's the case for a wood furnace that's in the basement though. I'd guess it follows the same rules, but not sure. I'd ask the manufacturer.
NateHanson is offline   Reply With Quote
Old 02-25-2008, 11:30 AM   #4
wgi
8 inch
6 inch
no, but i know it was built in 1992 when the previous owner had their fuel oil furnace replaced.
wood stove insert Karpol General DIY Discussions 5 11-25-2007 11:56 AM
Catalytic or Non-Catalytic Wood Stove? K&G's Cabin General DIY Discussions 1 02-06-2007 01:06 PM
Chimney Liner vs New Furnace jeff_connors HVAC 4 01-11-2007 12:41 PM
Advice Needed re: Chimney Liner for Oil Furnace Mike_R HVAC 3 11-27-2006 03:04 PM
