-   -   Oil Furnace / Wood Stove Chimney ?? (http://www.diychatroom.com/f17/oil-furnace-wood-stove-chimney-17483/)
wgi 02-22-2008 06:25 PM
I have a fuel oil furnace with a clay lined masonry chimney. I'l like to set a wood fired hot air funace along side of the oil furnace. Is there any reason I can't tie into the same chimney ahead of the thru wall thimble, but after the draft inducer on the output of the furnace? Would this cause any problems for either of the heat sources?
redline 02-23-2008 12:50 PM
What size is the clay lining?
What diameter is the fuel oil vent pipe?
What size will the wood vent be?
Have you had the chimney inspected?
NateHanson 02-23-2008 02:46 PM
I know a wood stove can't share a flue with any other source. I'm not sure if that's the case for a wood furnace that's in the basement though. I'd guess it follows the same rules, but not sure. I'd ask the manufacturer.
wgi 02-25-2008 11:30 AM
8 inch
6 inch
no, but i know it was built in 1992 when the previous owner had their fuel oil furnace replaced.
