Oil Furnace Won't Start - Nothing Happening - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 09:15 AM   #1
Switch is on - got 120 v at j-box, thermostat OK, changed filter at tank outlet, changed filter at pump inlet, changed nozzle, pressing reset on primary control does nothing. Jumped L1 to pump motor. Works fine - able to bleed line.
Supply house (and I) thought it has to be primary control.
Changed Honeywell Primary control - still nothing. This control gives a shaking green, indicator light for approx 2 - 3 sec, then the light goes out, then a single blink every four sec. I'm assuming this is ERR 1: slow/failed ignition.
Removed & visually inspected gun assy when changing nozzle - looks OK. Counter person at supply house thought so too.
khaas1 is offline   Reply With Quote
Old 03-01-2013, 10:38 AM   #2
Rewards Points: 446
You said thermostat was ok....... would you mind elaborating on that a bit more?
Your description leads me to believe that the thermostat is not telling the burner to run. At least that is the first thing that came to mind.
old_squid is offline   Reply With Quote
Old 03-01-2013, 03:18 PM   #3
I jumped it at the furnace.
Old 03-02-2013, 05:12 AM   #4
An old Tradesmen
Rewards Points: 8,154
Disconnect cad cell wire and see if it runs then.
Old 03-02-2013, 11:58 AM   #5
On the Primary Control there are two cad wires. Unplugged both - nothing.
Old 03-02-2013, 04:11 PM   #6
An old Tradesmen
Does your primary have a separate terminal for the high limit. if so, your high limit may be open.
Old 03-03-2013, 08:48 AM   #7
There is a spot labelled "limit" (red) but no male plug like the others. Is there a way to check or reset?
Old 03-03-2013, 08:57 AM   #8
An old Tradesmen
Post full model number of the primary.
Old 03-03-2013, 09:26 AM   #9
Current primary: Honeywell R7284
Replaced old primary (R7184B) with this model.
Old 03-03-2013, 09:58 AM   #10
An old Tradesmen
I haven't used that one yet. that has the diagnostic display right.
Did you try jumping the TT terminals and see if it runs then.
You do have line going to the L1 terminal, right. And have a good connection on your neutral.
Old 03-03-2013, 12:32 PM   #11
This one doesn't have a display, only the green indicator light.
Using my Klein (pen) voltage tester, there is power at L1 female plug and the two TT leads.
Previously jumped L1 to pump motor - worked. Able to prime line.
Tried jumping the two TT leads going to primary - nothing.
Admittedly not great with electric, I believe the neutrals should be the white wires - checked the two nuts/connections. They look good.
To reiterate, when I flip the switch the green indicator shakes/flickers (like it's trying). Then it goes out and after three or four secs gives a single blink every three or four secs.
Old 03-04-2013, 08:41 AM   #12
Devil Dog
handyman_20772's Avatar
Rewards Points: 77
Sounds like your control has locked you out, hold down the reset button for about 30 sec. until you see it flash then release. The motor should come on for 10 seconds and then the burner will come on after the cad cell sees the flame. If this doesn't happen I would check the ignitor next, changing this out is pretty easy and while your at it I'd get a new cad cell.
handyman_20772 is offline   Reply With Quote
Old 03-04-2013, 03:53 PM   #13
An old Tradesmen
On lock out. Isn't it suppose to have a red LED that stays on.
Old 03-04-2013, 05:24 PM   #14
Yeah, the error for a lockout is 1/2 sec on, 1/2 sec off. Hold reset for 45 sec - I tried this previously.
To me, signs point to the ignitor. I'm assuming the ignitor is the two springs that contact the gun assembly (where nozzle is connected to)? The part that hinges?
I've seen them test the ignitor on You Tube, but it looked like they had it out and connected to a separate power source!? How could I test mine?
Really appreciate the input!
Being so stingy to call an HVAC contractor because I have a barrel stove that (easily) heats my 1200' ranch.
Old 03-04-2013, 05:37 PM   #15
An old Tradesmen
If it would be the ignitor. The motor would still run until the safety timed out.
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Gas Furnace Won't Stay Running / Thermostat Set High To Start _scott HVAC 6 03-23-2011 07:27 PM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 06:48 PM
Oil Furnace Won't start ScottEW HVAC 0 10-05-2010 08:26 AM
clare furnace needs reset to start dustin020 HVAC 2 10-15-2009 06:06 PM
