Oil Furnace Wont Fire Up - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 01:59 PM   #1
Oil Furnace wont fire up
Oil furnace wont fire up.It was pumping oil but no ignition
Genem is offline   Reply With Quote
Old 01-20-2012, 02:37 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,410
Ayuh,... Could be the ignition coil, or igniters...
Could be Alotta things, but you'll need to pull the burner to see...
Bondo is online now   Reply With Quote
Old 01-20-2012, 03:07 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
The most common cause of ignition failure is a bad transformer. Make sure you have power going to it. Don't touch the bare copper busses coming out of it........unless you'd like a real charge, say a few thousand volts. And don't hit the reset button more than once. You'll load the burner chamber with a lot of raw oil that will burn off once it lights.
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Changed gas ball valve and York furnace won't fire, please help. philsoldat HVAC 35 11-03-2010 11:12 AM
furnace indicates calling for heat but no fire pocketrods HVAC 1 10-29-2010 08:09 PM
my furnace wont fire... please help! chrider88 HVAC 7 01-22-2010 09:43 PM
Luxaire furnace fails to fire cheesegrump HVAC 1 01-10-2006 07:36 PM
