Oil Furnace Warranty/Installation ? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2009, 08:20 PM   #1
I had a new oil furnace installed about 8 months ago. Furnace heats hotwater and baseboard heat. Looks like the tempering valve/mixing valve has gone bad. I have the valve set to 160 degrees and it barely reaches 110. Question is should this part be replaced for free by the company that installed the complete system?
Thank you for your response.
fgermana is offline   Reply With Quote
Old 01-16-2009, 09:25 PM   #2
No. Was it in the contract to replace? Did you have hot water for the last 8 months?
bervin306 is offline   Reply With Quote
Old 01-16-2009, 09:31 PM   #3
What he said.
If it was included in your install, than yes. Check your warranty papers to seehow long a warranty you have.
hvaclover is offline   Reply With Quote
Old 01-16-2009, 11:44 PM   #4
An old Tradesmen
Rewards Points: 6,588
As others, if they installed it new with teh boiler, yes, it should be included in their warranty.
Why, what did they say.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
