Oil Furnace Want Start After Changing The Filter And Pushing The Reset Button - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 08:09 PM   #1
Oil Furnace want start after changing the filter and pushing the reset button
How do I get the furnace to light the pilot after replacing the filter. I pushed the reset button and it still doesn't light
pjsnipes is offline   Reply With Quote
Old 11-06-2010, 10:17 AM   #2
Rewards Points: 1,596
I'm no pro but as far as I know oil furnaces do not have pilots. Do not keep hitting the reset button until someone here can help; everytime you hit it, it should be dumping oil into combustion chamber and it will cause you more problems. What filter did you replace?
bob22 is offline   Reply With Quote
Old 11-06-2010, 02:28 PM   #3
An old Tradesmen
Rewards Points: 7,376
Did it work before you changed the oil filter.
Did you bleed the oil filter before you tried to run the furnace?
