Oil Furnace Reset Only Works If... - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 04:58 AM   #1
Oil furnace reset only works if...
Hi
Sorry if this message is redundant. I submitted it once by the IE page hung up on me so I don't know if it got through.
Familiar problem: furnace shuts off, won't start when reset is pushed.
flame sensor, stack, control board, ignitor, nozzle, etc.?
Pick one and explain why: if I first toss a lit paper in the combustion chamber to burn off the residual oil from the failed start - now the reset works - every time?
What does burning off the residual oil rectify?
Got me!
Thanks for any help!
RAF48 is offline   Reply With Quote
Old 12-22-2010, 06:37 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
It should NOT be tripping the reset. If it is the old school stack control in the smokepipe type the heat from your paper trick may move the spring in it enough to reset it. Need to get the unit properly service B4 you start getting serious delayed ignition or other BAD problems.
Old 12-22-2010, 02:08 PM   #3
Hi Yuri
Thanks for the prompt reply. Your answer is a reasonable one that I will take a look at. Mine is not the 'old' flue-pipe stack, however your idea has got me thinking along a line I hadn't before.
I'll post back if/when I get it sorted out.
Best Regards and Thanks
raf48
Tags
oil furnace reset only if
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Furnace only works with door off CWinGA HVAC 3 12-05-2009 04:36 PM
Furnace Reset Issue Syzygyone HVAC 2 12-01-2008 08:11 PM
