Oil Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 06:05 PM   #1
Question
Oil furnace question
Hi,
I have a question regarding my oil furnace that is 16 years old and cleaned every year. The problem is when it comes on it pops and shuts off for about 2-3 seconds and then comes back on and continues to do this for the duration of the time that it is on. What could be the problem?
JO-ANN is offline   Reply With Quote
Old 10-09-2008, 10:32 AM   #2
Another DIY Zombie
Rewards Points: 264
More information is needed on this.
I assume that there is a time when the furnace is not on, then the thermostat calls for heat and the unit fires up, then run awhile, then "pops" and shuts off then comes right back on?
Part of this sounds like short cycling.
If you are near the furnace, can you pin-point where the "pop" sound is coming from?
javan is offline   Reply With Quote
Old 10-10-2008, 09:25 AM   #3
Furnace problem
Yes it is coming form the smoke stack. I also got oil last week and now I'm thinking that stirred up the sediment in the bottom of the tank and clogged something.
Old 10-10-2008, 12:12 PM   #4
Another DIY Zombie
Rewards Points: 264
Thinking that it would be best to call in for service.
Old 10-10-2008, 11:11 PM   #5
fURNACE PROBLEM
I called and he had to blow out the oil line using 3 cans of co2. Thanks for your help.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Question Re: New Furnace and Duct Sizing DSimo HVAC 3 06-17-2008 08:24 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Furnace size question IGOTTAHEMI HVAC 6 03-16-2007 06:57 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
