-   -   Oil furnace question (http://www.diychatroom.com/f17/oil-furnace-question-29607/)
JO-ANN 10-08-2008 05:05 PM
Hi,
I have a question regarding my oil furnace that is 16 years old and cleaned every year. The problem is when it comes on it pops and shuts off for about 2-3 seconds and then comes back on and continues to do this for the duration of the time that it is on. What could be the problem?
javan 10-09-2008 09:32 AM
More information is needed on this.
I assume that there is a time when the furnace is not on, then the thermostat calls for heat and the unit fires up, then run awhile, then "pops" and shuts off then comes right back on?
Part of this sounds like short cycling.
If you are near the furnace, can you pin-point where the "pop" sound is coming from?
JO-ANN 10-10-2008 08:25 AM
Furnace problem
Yes it is coming form the smoke stack. I also got oil last week and now I'm thinking that stirred up the sediment in the bottom of the tank and clogged something.
javan 10-10-2008 11:12 AM
Thinking that it would be best to call in for service.
JO-ANN 10-10-2008 10:11 PM
fURNACE PROBLEM
I called and he had to blow out the oil line using 3 cans of co2.:no: Thanks for your help.
