Oil Furnace Pump Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 06:00 PM   #1
oil furnace pump leaking
I had an outside underground tank on my oil furnace. It went south and could not be fixed by my oil furnace company. I installed a 275 gallon indoor tank. The oil pump had an intake and a return line on it when I had the underground tank. I was under the impression you did not need the return on the pump when you had a short run (and the tank did not have a place for a return to connect to) so we removed and plugged the return line. I fired up the pump and oil is spewing everywhere. Have I put too much pressure on the pump by not using a return line and blown all the seals? If so, how is a return normally routed into an indoor 275 gallon tank? Or is there a different pump I am supposed to use when I have a single supply line?
steve104high is offline   Reply With Quote
Old 11-15-2012, 08:15 PM   #2
Inside the fuel pump is a set screw with an Allen head on it. It needs to be removed when only using a one pump system. However that doesn't matter at this point because the seal on the oil pump is now blown. You will need a new pump.
Flyers28 is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
American Standard 90%HE Gas Furnace leaking gas blueydgal HVAC 1 10-30-2011 02:26 PM
Why can't I make up my mind! Ductless split? ducted heat pump? Furnace W/ AC coil.... penguinchicken HVAC 3 10-11-2011 08:25 AM
Apollo Forced Air Furnace, leaking water sethfc HVAC 29 04-06-2010 02:31 PM
How to Prime Oil Furnace Pump AndrewF HVAC 2 01-28-2010 08:18 AM
