Oil Furnace Problem - Help - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2006, 03:31 PM   #1
Unhappy
Have an older oil-fire furnace with problems. Living in So. Cal. means I can't find anyone to service it. Typical furnace (O.F.F.C.O. Brand probably obsolete, but typical design with good Beckett system), honeywell fan limit controller, White-Rogers controller, etc. The system will start up, ignite and burn, and the fan will turn on (cycle a few times). The system will run for some time (5 - 10 minutes) but will shut down before the thermostat tells it to. I've watched it and the fan controller does not overtemp. The system will trip, the fan will continue on a cool down cycle and I will need to reset to get it to start again. I've replaced the L4064 fan controller and get smoother fan control but still trips. Now I'm going to replace the W-R controller.
Could it be the flame detector shutting down ignition?
dputnam is offline   Reply With Quote
Old 01-17-2006, 08:58 PM   #2
Before doing that check your flame sensor. If you need help with that PM me.
oddjob is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
Comfortmaker furnace problem Big Red HVAC 11 02-10-2008 06:56 PM
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
