-   -   Oil Furnace Problem - Help (http://www.diychatroom.com/f17/oil-furnace-problem-help-1670/)
dputnam 01-17-2006 02:31 PM
Have an older oil-fire furnace with problems. Living in So. Cal. means I can't find anyone to service it. Typical furnace (O.F.F.C.O. Brand probably obsolete, but typical design with good Beckett system), honeywell fan limit controller, White-Rogers controller, etc. The system will start up, ignite and burn, and the fan will turn on (cycle a few times). The system will run for some time (5 - 10 minutes) but will shut down before the thermostat tells it to. I've watched it and the fan controller does not overtemp. The system will trip, the fan will continue on a cool down cycle and I will need to reset to get it to start again. I've replaced the L4064 fan controller and get smoother fan control but still trips. Now I'm going to replace the W-R controller.
Could it be the flame detector shutting down ignition?
oddjob 01-17-2006 07:58 PM
Before doing that check your flame sensor. If you need help with that PM me.
