Oil Furnace Not Lighting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 08:47 AM   #1
oil furnace not lighting
last winter the furnace was having troble staying light .....i change the nosle and fliter at the tank witch look like it was never changed ......so after that it was running better but would shut off after a while and u would need to reset .......but know here its coming fall its been running fine right up till lat night and it wont light at all ......thinking mybe the clad cell mite be bad or the coil ? if anyone can help shad some light plase so grealty aprade ...ps its a old oil furance if u need more info just ask and ill do my best to get it thanks agine
b4322558 is offline   Reply With Quote
Old 09-26-2010, 12:01 PM   #2
An old Tradesmen
Rewards Points: 6,498
The Cad cell has no effect on it lighting.
Might want to pull the nozzle assembly again, and see what it looks like.
Old 09-26-2010, 12:27 PM   #3
oil furance
it would run but it wouldnt light......i took the screw out and touch the coil on the rods and it light up and its running nice and clean and everyone in a while u will need to reset and it will run for a week it will kick out agine
Old 09-26-2010, 12:48 PM   #4
An old Tradesmen
Its not the cad cell.
When is the last time the burner set up was checked? Over fire draft, smoke, CO2, stack temp.
Old 09-26-2010, 04:39 PM   #5
furance
i dont have a clue ....if thur are something that i can check can u tell me how to do thur checks .......bc the last time it was work on april of 2008.....w they put a new motor in and glald cell and ing coil
Old 09-26-2010, 05:15 PM   #6
An old Tradesmen
Reclean the nozzle assembly. And install a new nozzle again.
Nozzles are not something that is reliable.
Old 09-26-2010, 05:28 PM   #7
oil furnce
k ....how do i check the burner set up ?
how do i check over fire draft ?
how do i check smoke co2 ?
how do i check stack temp ?
thanks for the help
Old 09-26-2010, 05:49 PM   #8
An old Tradesmen
thanks for the help
With a 500 or so dollar Bacharach Fyrite test kit.
Not something everybody has laying around there house.
My setup for checking burners is a fair bit more yet.
Old 09-26-2010, 11:11 PM   #9
oil furnce
ic well am very greatly aprased i spell that wrong ...but i thank u alot for the help
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 12:47 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Gas furnace not lighting, but damper moves tevans HVAC 5 11-15-2006 10:01 PM
