Oil Furnace Not Blowing Hard - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 02:08 PM   #1
Oil furnace not blowing hard
For the last two days the furnace began vibrating and last night it became quite violent with the vibration. This morning it suddenly made a loud clunking noise as if some part fell off in the furnace room. Now it is not blowing at all. I know absolutely nothing about furnaces or what they should look like. What should I be looking for?
otackett is offline   Reply With Quote
Old 03-19-2012, 02:23 PM   #2
Rewards Points: 1,778
Likely a broken blower wheel.
Usually in the bottom of the furnace behind an access panel.
Google furnace blower wheel replacement; they'll be tons of pics/videos.
bob22 is offline   Reply With Quote
Old 03-19-2012, 03:49 PM   #3
found it
Okay, thanks. I did find the broken piece. A piece of the metal belt pulley snapped in half. Do I need to replace the entire motor or is that piece detachable? Where do I begin looking for it? Thanks again for all your help.
Old 03-19-2012, 04:16 PM   #4
how
Rewards Points: 1,104
If that's the pulley that's attached to the motor it's either a solid pulley thats broken or a split pulley thats come apart. Watch out that the edges of that pulley have not worn down to knife edge sharpness.
Turn off the furnace power, turn the stud or allen key on the hub of the pulley that is biting into the motor shaft counterclockwise a few full turns. If the shaft is in OK shape, what's left of the pulley should slide off the end of the shaft. If any parts of the end of the motor shaft are wider than 1/2" then it becomes more difficult to remove. WD 40 , a file for bringing the shaft back into round & a large screwdriver crowbaring between the motor and the pulley are not unheard of removal tools.
Take that pulley into an HVAC supply house for an exact replacement. Even many of the box hardware type stores in my neighbourhood carry a variety of pulleys for what I'm assuming is a 1/2" shaft.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
otackett (03-19-2012)
Old 03-19-2012, 04:41 PM   #5
Perfect! I was able to get it off and I am on my way to get a replacement. Thank you sooo much...and they say women aren't handy.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace Fan Blowing Outside? dmed HVAC 4 11-08-2011 06:43 PM
Bryant 383KAV Furnace - Continuously Blowing Cold Air josh42bigO HVAC 0 12-01-2010 02:34 AM
Wall furnace blowing out kwoodsong General DIY Discussions 5 12-09-2007 06:14 PM
