Oil Furnace Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2011, 08:14 AM   #1
oil furnace noise
When my oil burning furnace turns on I get a whining or moaning noise on the floor above the furnace but not at the furnace itself. I've had two techs here and they can't find out what the problem is. This happens not just for the call for heat but also when it is just heating the water. Air in the pipes is not a factor I believe, as I get good circulation in all 3 zones.
Mark Wheet is offline   Reply With Quote
Old 12-23-2011, 10:04 AM   #2
Noise
Where's the exhaust routed? Could it be the contraction/expansion of the exhaust pipe or just the exhaust resonating with floor joists?
eugenet1979 is offline   Reply With Quote
Old 12-23-2011, 10:14 AM   #3
HVAC Tech/ Browns Fan
Did they check the the burner blower motor?
Tator1076 is offline   Reply With Quote
Old 12-23-2011, 10:16 AM   #4
The plastic couplen between pump and motor maybe out of balance or start to break
Old 12-23-2011, 02:41 PM   #5
oil furnace noise
They didn't check the burner blower motor. Pretty much all they did was listen to the noise and said they had no idea what it was. They said they have never heard that before. I know with a gas furnace there may be air leaking out of the blower but I don't know if it is the same with an oil burning furnace. I know very little about the workings of a furnace.
Old 12-23-2011, 03:39 PM   #6
Need check that out.
Old 12-23-2011, 04:54 PM   #7
Rewards Points: 1,548
Is the furnace getting enough combustion air, preferably from the outside? If the basement is quite sealed then combustion air may be whistling as it seeps in from cracks or under doorways to the upstairs.
Old 12-24-2011, 07:10 AM   #8
I'm sure there's enough combustion air and I will recontact the tech to check the burn blower motor. Let you know how I make out. Thanks for the input.
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
furnace noise debd HVAC 2 11-28-2009 02:38 PM
Forced air furnace blowers making noise CowboyAndy HVAC 9 11-26-2008 12:56 AM
furnace making noise ja3118 HVAC 1 11-24-2008 10:51 AM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
