Oil Furnace Needs Cleaned - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 01:59 AM   #1
oil furnace needs cleaned
this furnace hasn't been cleaned in at least 12 yrs. i'm hoping that's the cause of all the soot, and why it won't fire. i've changed the nozzle, filter, bled the air. to remove what i'm guessing are the heat exchangers looks very difficult (see pic). is it necessary to open/clean heat exchangers right above the burner, or is it too hot for soot to accumulate so close? does soot start to accumulate at the chimney then build up towards the furnace? from the back end (see pic), i can see buildup on the sides, but they are not completely blocked. i had a tech come out, and i'm guessing he didn't want to clean the thing.
i can upload more pics if necessary.
mscotthorn is offline   Reply With Quote
Old 09-30-2009, 05:26 AM   #2
An old Tradesmen
Rewards Points: 6,500
The part where the flue pipe connects, probably comes off for access.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
