Old 11-06-2009, 05:25 PM   #1
Default Oil Furnace Help
Hello all i am having issues with my Hallmark HSLD84 oil furnace it was working great when i first fired it up after refueling for this up coming winter but now it will not fire up the pump works the igniter is working but it just won't start any suggestions would be appreciated.....
Stumped at the moment....
Thanks in advance.......
dgrn75 is offline   Reply With Quote
Old 11-06-2009, 06:27 PM   #2
old pro
How do you know the pump and igniter are working? What procedure did you use to determine this.
Old 11-06-2009, 10:35 PM   #3
I opened the bleed valve and it is pumping and i opened the igniter cover and it was arching on both leads.....
Old 11-06-2009, 10:48 PM   #4
old pro
You may need a new nozzle. It may be partially plugged and the spray pattern is incorrect. Dangerous to use that way as unburnt oil can accumulate in the combustion chamber and then light and have a runaway fire. DO NOT press the reset button more than once. The high efficiency burners have special nozzles and critical settings so it is best to get a Pro to setup the burner for maximum fuel efficiency and proper combustion.
Old 11-07-2009, 01:00 AM   #5
You may want to change the oil filter cartridge. It could be partially restricted.
Just because oil is coming out of the bleed hole on the fuel unit, doesn’t mean that the oil pressure is correct.
I agree that these things are usually best handled by a pro.
KayJay is offline   Reply With Quote
Old 11-07-2009, 01:09 AM   #6
Thank you everyone i have a heating and air guy coming out Sunday i don't want to risk anything......
I greatly appreciate all who responded....
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Hi, I'm Mark Sullivan for Expert Village and today we're going to teach you how to change the oil in a standard internal combustion automobile engine. Check filler cap, check dipstick. I'm going to check the oil filter one more time to see if I can... Read More »
Hi, I'm Mark Sullivan for Expert Village and today we're going to teach you how to change the oil in a standard internal combustion automobile engine. The next thing you would need to know is be careful, there are hot components on the motor. We have... Read More »
Hi, I'm Mark Sullivan for Expert Village and today we're going to teach you how to change the oil in a standard internal combustion automobile engine. So the next thing we're going to do is go under the vehicle and open the oil drain plug and we will let... Read More »
This is a center chimney burner also. This is used to raise and lower the wick. I don't know if you can see that and the higher you raise the wick, the more flame you are going to get and more light. But you are also going to get more smoke. There was a... Read More »
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 09:06 AM
Furnace air filtration advice stephen_smith HVAC 5 01-12-2009 09:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 5 11-07-2008 06:52 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
