Old 01-15-2009, 11:47 PM   #1
Question
Oil furnace does not fire up
Hello,
I have 10 year old Rheem oil furnace. My oil tank (I think it is 250 gallons) is 25% full. Two days back the furnace stopped blowing hot air. It looked like the blower in the furnace was working but the furnace was not ignited. So there was only cold air blowing from all the vents.
I called the technician and he replaced something (probable nozzle). Then the furnace worked fine during evening hours but then again next day morning it stopped working. So I called the same technician again, he came and checked the furnace. He pressed the trip button and restarted the furnace. It fired up this time and it started blowing hot air. After checking few things he said that the oil temperature was very low and so furnace did not ignite. the temperature on Oil tank was 29 degree F. He checked the wall temperature and it was 22 degree and around the oil pipe (leading to furnace) it was around 27 or 29.
Now after few hours of furnace working it is again blowing only cold air (in between it went through couple of cycles of on/off based on temperature setting).
So is it true that at 29 or probably 27 degrees the oil becomes thick and so oil furnace won't fire up? It is likely that during night hours the temperature around the oil tank might be lower then 29 degrees.
Please help.
sbhavinm is offline   Reply With Quote
Old 01-16-2009, 04:00 AM   #2
my furnace will not prime
jaswol12 is offline   Reply With Quote
Old 01-16-2009, 07:18 AM   #3
An old Tradesmen
At 27°, the oil will burn just fine.
A lot of people have their oil tanks outside, and the temp is 15° and working just fine.
There is also an additive that can be put in the oil, to keep it flowing at temps below 0°F.
Call him back, he missed something on the 2 previous calls.
If it was too cold for the oil, then when he was there, he wouldn't have been able to get it to flow or burn.
Could, also be the new nozzle he installed, is not good.
But, it could also be one of the following.
Incorrect ignitor setting.
Weak ignition transformer.
Improper combustion air setting.
Restricted/clogging oil filter.
Incorrect nozzle was installed by accident.
Dirty/weak cad cell.
Primary control going bad.
Loose wire connection.
Carbon build up at the air cone head.
Weak oil pump.
Dirty oil pump strainer.
Clogging oil line.
Old 01-17-2009, 12:03 AM   #4
It was transformer. I got transformer replaced and furnace is working now.
Bhavin
Old 01-17-2009, 04:38 AM   #5
I'm guessing that when you say transformer it was the high voltage ignition transformer, but that is not my question. I'm curious about how old of a system do you have that allows the blower to run without heat?
hychesee is offline   Reply With Quote
Old 01-17-2009, 08:06 AM   #6
I think you are correct. I is high voltage ignition transformer. I don't know the exact technical name.
Anyways, my furnace is 10 years old (1998 Rheem High Efficiency furnace).
-Bhavin
Tags
fire up, oil furnace
More On This Topic
The basics of furnace use in glass blowing; learn this and more in this free arts and crafts video by a glass blowing expert. Read More »
Installing or replacing an air filter in a furnace is important to keep the air in the home allergen- and pollution-free. Find the right size, vacuum out the interior, and change it out often with information from a professional house cleaner in this... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Red-eyed tree frogs, or "monkey frogs," are small nocturnal amphibians. They usually grow to be about three inches long. Red-eyed tree frogs have orange feet and hands, a bright green dorsal and blue or purple stripes on their flanks. Their care is... Read More »
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 08:55 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Fan runs constently Furnace won't fire BSO HVAC 1 11-16-2008 09:40 PM
Gas furnace won't fire Peter Weber HVAC 2 02-08-2007 03:19 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
