| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Check a Furnace Filter
by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Cleaning up After a Belly Casting
by Expert Village
In this clip we talk about the cleanup process after your belly cast has come off. You want to make sure that you have some clean water available to wipe the model off. The plaster, especially on the sides of the belly will still be on her skin. You want... Read More »
Removing Sediment from a Kettle
by Expert Village
Now I'm going to show you how to take sediment out of an electric pot. When you live in a place where the water is very hard you get sediment very often on electric parts. An easy way to take it off is we use vinegar which most homes have handy. What we... Read More »
How to Change a Furnace Filter
by Expert Village
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
How to Level a Porch
by eHow.com
Whether your family will be comfortable on your porch depends on whether you've built it at a proper level. A level porch helps furniture stay in place and keeps glasses from sliding off your table onto the ground. You need to know how to find and... Read More »
