Oil Furnace - Black Soot - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 11:28 AM   #1
Oil Furnace - black soot
I installed a used oil furnace in my shop. After about 1 year I now have black soot coming out of the air ducts. I also have the air filters turning black, not dirt but oil black.
Do I have a crack in the burner chamber... or something else? What do I do?
Warren21 is offline   Reply With Quote
Old 02-08-2009, 11:45 AM   #2
An old Tradesmen
Rewards Points: 6,060
You might.
Could also be a blown clean out seal.
Could be other combustion problems.
Heat exchanger needs checked.
If not a problem with the heat exchanger.
A good cleaing, and a proper combustion set needs to be done.
Old 02-08-2009, 05:53 PM   #3
JohnH1's Avatar
What been said. But did you mean a used furnace or used oil furnace as in burning used car oil etc.
JohnH1 is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Boiler heater blowing black soot when it fires rickeyraye HVAC 2 01-06-2009 09:36 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
