Oil Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-21-2009, 04:34 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
Check if there are any tax breaks/incentives for new furnaces. If there are you may want to do it sooner than later, they sometimes expire and you don't want to lose out.
Old 10-21-2009, 04:56 PM   #17
Yes
Originally Posted by LOVE2DIM View Post
I will try what you suggested. I also read somewhere about cleaning ceramic near the electrodes on the transformer. You think that may be causing any of my problems?!
Turning all power to the furnace off is simply switching the emergency switch to the off position, correct?
Yes, shut the switch off and try reseting the button if nothing happens you got it.
Replacement sounds real good.
SULTINI is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
