Oil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 01:18 PM   #1
Oil furnace
I have a oil furnace and is only blowing cold air I hit the reset switch and is still blowing cold air
pablodelgado is offline   Reply With Quote
Old 11-24-2011, 01:28 PM   #2
An old Tradesmen
Rewards Points: 7,816
Made this its own thread, please don't hi jack other peoples threads, thank you.
Old 11-24-2011, 01:31 PM   #3
Sorry just learning how to post
Old 11-24-2011, 01:36 PM   #4
An old Tradesmen
Got oil in the tank?
When was the last time it was cleaned and serviced?
Old 11-24-2011, 03:27 PM   #5
REP
Could be anything ,over 100 differant things.I can't tell you anything from what you have said.
The only thing I can tell you is that until you figure it out DO NOT HIT THAT "RESET" BUTTON AGAIN.
iF YOU HAVE OIL AND IF YOUR PUMP IS WORKING AND IF YOUR FILTER IS CLEAN AND IF AIR HASN'T SOMEHOW GOTTEN INTO YOUR FUEL LINE AND IF YOUR NOZZLE ISN'T PLUGGED, Then hittingt the reset button is pouring oil into your combustion chamber.You don't even want to think about the burner catching on with 2 or 3 squirts of oil already in the combustion chamber.
Now its time to call someone to set it up with instraments.Long gone are the days when people could set a burner by eye.Doing it by eye might get you heat but could cost you $400 extra this year.
REP is offline   Reply With Quote
Old 11-24-2011, 03:31 PM   #6
Rewards Points: 582
yes agree with rep....DON'T HIT RESET BUTTON AGAIN call for service.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
