Old 02-03-2009, 02:04 PM   #1
Oil fired furnace replacement ideas
I will need to replace my oil (hot water baseboard) furnace next year and would like to make sure I don’t miss an opportunity to lower costs.
Should I replace it with another oil furnace or something else?
2300 sf , 4 zone home, Connecticut
I do not have natural gas in my area, would require a tank.
Another consideration, the 275 gal oil tank in my basement is 42 years old and will also need to be replaced soon.
Davidb6 is offline   Reply With Quote
Old 02-03-2009, 02:27 PM   #2
tk03's Avatar
The only way to guarantee a fuel savings is have a heat loss done and do not use a domestic hot water coil in the new boiler if you stay with oil.
Have it properly piped. Most equipment today is oversized when installed and decreases efficiency and increases maintenance. Proper sizing and installation should save 25% - 40%.
For more info see on the importance of heat losses.
http://www.comfort-calc.net/faq.html
tk03 is offline   Reply With Quote
Old 02-03-2009, 04:12 PM   #3
Good advise on getting the heat loss of the house checked either way I go.
I've read that a natural gas furnace is more efficient than an oil furnace. Is that difference exaggerated? If not, it may make more sense to switch away for oil just because of the advanced technology alone.
One disadvantage of natural gas is I would need to install a tank in my back yard...not very appealing.
Old 02-03-2009, 05:06 PM   #4
Master General ReEngineer
Ayuh,... Natrual Gas is piped from a Utility,... You're thinking of Propane, LPG....
If there's never been a Water in the fuel issue with your 40 year old tank,...
It'll last Another 40 years if it's kept Water Free...
It's Water laying along the bottom that Rots them out,... No Water, they last Forever...
Old 02-03-2009, 06:45 PM   #5
Oh....Natural Gas is piped from a Utility
Good thing I'm starting my research early.
No water that I know of in the tank but there is a very slight sign of surface rust...the kind you can wipe off with a rag.
Are propane & LPG burners the same as natural gas...that is, is there technology considered better then oil fired? I wonder if the same logic applies..if the efficiency of the burner is higher than oil...use it.
Old 02-03-2009, 07:22 PM   #6
Ayuh,... The outside rust usually isn't the problem,...
It's the Inside,..
Along the very bottom, where the water will lay under the oil if it can...
If your tank was set up right,+ it appears it was,...
It shouldn't play into your decision,..
Other than getting the monster Out of the house if you switch....
Old 02-04-2009, 09:31 PM   #7
tk03's Avatar
The gas appliances are more efficient as AFUE efficiencies go. But remember you get more BTU's out of fuel oil. The idea of oil having more service is not true anymore as the higher efficiency equipment require annual maintenance.
Old 02-04-2009, 10:13 PM   #8
Extreme DIY Homeowner
Scuba_Dave's Avatar
Curious as to why not get the domestic hot water coil?
I can buy one at a great price - Weil-Mclain - & it has the water coil
I had only planned on using it during the season when the heat was on
The rest of the time hot water would be supplied by electric
With electric costs oil is more cost effective
And as long as it is running in the winter.......
Old 02-04-2009, 10:20 PM   #9
tk03's Avatar
Most expensive way to make hot water. See my opinion at the following link
http://www.comfort-calc.net/Domestic...r%20_Coil.html
Old 02-05-2009, 07:32 AM   #10
An old Tradesmen
Tankless coils in a boiler are a waste of money.
Why do you want to maintain a high temp in the boiler, so that it increases your standby loss, and pts more money up the chimney then need be.
Old 02-05-2009, 10:34 AM   #11
You guys are showing me how little I know...thanks!
tk03, I'm very new at this but if I have how water baseboard as heating wouldn't my domestic hot water be free...at least during the winter months?
More On This Topic
A worn barbecue grill burner can ruin your outdoor dinner. If your barbecue grill burner produces a yellow or orange flame, causes too much smoke or just cooks unevenly, you can probably solve the problem with a new burner. An inexpensive burner will... Read More »
Hi I'm Betty Ingham on behalf of Expert Village. We would put little things all around that. As in Christmas ornaments or some more smaller patterns or some more smaller items. Now we try to utilize every step, every piece, every inch of our kiln because... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Hi I’m Anna from annawillowglassdesign.30art.com and I am going to show you how to make an interesting shaped Christmas ornament using an optic mold. Now I am going to go over here and gather out of the furnace onto the blow pipe. I am actually... Read More »
Most propane BBQ grills are versatile and easy to use and operate. By reading the owner's manual for your particular propane BBQ, and by following a few basic safety tips, you will be able to light it consistently. Read More »
Help - Problem with Oil Fired Forced Air Furnace JohnF HVAC 13 01-31-2009 11:04 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 5 11-07-2008 06:52 AM
Furnace Replacement Options? Genhawk21 HVAC 5 01-11-2008 11:41 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
