Oil Fired Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2009, 12:09 PM   #1
oil fired boiler
Help, my boiler won't fire...Its getting oil but doesn't want to ignite...any suggestions
daddydude22 is offline   Reply With Quote
Old 01-29-2009, 12:39 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,...
Pull the Burner assembley,+ Clean it....
Then check the igntion Coil....
Bondo is online now   Reply With Quote
Old 01-29-2009, 12:40 PM   #3
Custom Cabinet Maker
Transformer, nozzle, controls one or a combo of all. If you havent changed the nozzle in a while that is the simplest eziest thing to start with.
Transformer: In darkness, open inspection door and look into chamber while trying to fire it, do you hear arcing and see reflections of sparking? IF not then trans is not firing.
Are you 100% sure you are getting oil into the chamber? When was last time you changed the screen inside the oil pump?
Is the blower running? List can go on and on.
Blower NOT running then coupling is stripped.
Start with simple, then if no luck the fun begins
skymaster is offline   Reply With Quote
Old 01-29-2009, 04:07 PM   #4
Rewards Points: 5,336
What type of oil boiler is it? Chimney or direct vent? Last time it was tuned? Does it have a Carlin 60200 Rev b primary?
I take it you don't have a maintainance agreement with an oil company?
Ron
Old 01-29-2009, 04:35 PM   #5
Ron; R O F L M F A O CARLIN 60200 Rev B !!!!!!!!!!!!! I just finished that dance with my Weil Mc Lain. That was where I has headed but decided to go real simple at first
Old 01-29-2009, 04:47 PM   #6
An old Tradesmen
Rewards Points: 6,848
That method has cost more then one person their eyebrows, to say the least.
Old 01-29-2009, 05:02 PM   #7
Beenthere: I most certainly did not tell him to get his face close
Old 01-29-2009, 05:33 PM   #8
An old Tradesmen
Had a call at a moble home.
Got the standard, I only pushed the reset button once line.
Could tell by his wifes expression it was a lie.
Couldn't see how soaked the chamber was.
I pushed the reset to listen for the spark.
It decided to light this time.
I was out of the way of the flame, since I knew he pushed it several times.
But it hit the wall of the hall when it blew the sight door open.
And yes, the spring was working fine.
That was back in the early 80s.
Depending how much oil is in the OPs chamber, he doesn't need to have his face close. To get a serious burn.
Since that call. Any unit with a spring loaded sight door, I hold a screw driver against it, until I know its safe to look in.
Old 01-29-2009, 05:37 PM   #9
An old Tradesmen
You also didn't tell him to be carefull because it could ignite, and shoot a flame several foot out toward him.
Or, that if his combustion chamber is soaked with oil, he could lose control of teh flme, and burn his house down.
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 08:48 AM
Please help me stop my oil fired boiler from banging at the end of each cycle! snanancekivell HVAC 6 01-13-2009 04:12 PM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
Oil fired boiler need help with gustavus HVAC 4 11-30-2008 04:41 AM
