Oil Or Electric Furnace In Quebec - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2013, 06:33 AM   #1
Rewards Points: 93
Oil or Electric Furnace in Quebec
Hi,
Currently oil is running about $1 a liter. Electricity here in Quebec is cheap... about 6 cents a kilowatt.
We have an old oil fired furnace, old tank, no chimney liner, 3 year old heat pump. Our house is about 50 years old. the attic is well insulated, but the walls are not.
If you were upgrading your equipment what would you do?
DC variable speed fan?
air exchanger? (really needed with drafty walls?)
thermostat? What model?
Oil option
furnace ($1500??)
tank (1000$)
chimney liner (1000$)
Electric
furnace ($1500??)
50 ft 100 Amp wire (10$ a foot??)
Your thoughts?
Regards,
Terry
tls1 is offline   Reply With Quote
Old 10-12-2013, 07:43 AM   #2
Rewards Points: 1,684
At 6 cents no need to even look for my pencil much less my calculator for that one.
Next question
SeniorSitizen is offline   Reply With Quote
Old 10-12-2013, 08:20 AM   #3
Rewards Points: 93
they make it a little more complex...
The D Rate.
fixed charge of 41 cents a day (already pay that one).
then
first 30kwh/day is 5.41 cents/kwh
then it changes will be 7.78 cents/kwh
and
power above 50 KW (not sure if this is daily, monthly, etc)
winter (Dec 31 - March 31): 6.21 $ / KW
summer: 1.89 $ / KW
now currently I am on the DT rate for dual energy (oil and heatpump)
The DT rate...
when the temperature outside is warmer than -12C it's 4.40 cents / KWh (we heat with pump)
when the temperature outside is colder than -12C it's 21.26 cents / KWh (we heat with oil)(about 2 weeks a year)
summer: 1.89 $ / KW
Obviously going electric heat there is a higher risk of hitting that 50KW ceiling. And now we have smart meters that among other things can really calculate daily usage instead of monthly average.
Old 10-12-2013, 09:43 AM   #4
An old Tradesmen
Rewards Points: 7,816
Thats probably 50KWH a day.
I think I would check into upgrading wall insulation, before I upgraged equipment.
Old 10-12-2013, 10:03 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 150
I agree. plus you said you only heat with oil for 2 weeks when it is below -12C? then there is no point in replacing the furnace. I would get it properly setup by an experienced oil tech with a combustion analyzer. There are electric furnaces with X13 ECM constant torque motors that use a lot less elec if you want to run it continuos for circulation. Do the maths on the basic PSC and it is not good. W=E x I watts =volts x amps. figure that motor runs 3-4 amps x 120 volts = 500 watts. You would have to go to GE Genteq for more info on ECMs but they use a lot less. Electric furnaces also have a mild/cold weather switch to disconnect 2 elements in mild weather. you may get away with running it on mild and that would keep some cost down.
Keeprite makes a nice oil furnace with a true variable speed ECM motor but it is not going to be cheap.
http://www.keeprite.com/products/nomv.html
http://genteqmotors.com/products/
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 22 04-25-2017 03:02 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
