Oil Canning Noisy Cold Air Blockers - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 10:17 PM   #1
Rewards Points: 12
oil canning noisy cold air blockers
So, I got some nice oil canning sound that appear to be from the sheet metal blockers between the floor joists for my cold air returns. The joists are 2 x 12 - 16" o.c. and make the blockers do the oil can sound when you move weight from one joist to the next. Its compounded because the sound then travels up the wall and comes out the return vent in the room. I alleviated it some by unscrewing the metal blocker from one joist, prying it away slightly from the joist and subfloor and then sealing it with metal tape. There were cross bracing removed where the metal blockers went in so I tried to replace them but the joists still moved enough to make the metal pop.
Is there a better solution? So annoying. Brand new house, and full of annoyances like this. I am considering adding blocking between the joists closer than the current 8' spacing on the bracing to tie them together better. I also considered ripping out the metal blocking and using a piece of wood thats glued and screwed for the returns. Thoughts?
GaryZ is offline   Reply With Quote
Old 10-22-2010, 05:49 AM   #2
An old Tradesmen
Rewards Points: 6,590
Use duct board in place of those metal joist caps.
Tags
noise , oil can , popping
Toilet Flushing Causes Noisy Cold Water Pipes mrduck10 Plumbing 3 02-03-2010 07:10 AM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
