Oil Burner Will Not Stay On - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 09:25 PM   #1
Post
Oil burner will not stay on
Beckett AFG Oil Burner. Burner continually starts with a thump, runs a few seconds, then thumps again and runs briefly before another thump. This can last a day or two, then it will start and the Honeywell ProtectorelayŽ Oil Burner Control R8184 G4009 red button will pop. Removing the nozzle and cleaning the nozzle filter will give another day or two of the thump cycle operation. I believe there is a fuel supply problem and am eager to fix it. I cleaned the nozzle several times and the burner would run for a few days without interruption. I replaced the nozzle with a new one, but now the burner quits after about 2 minutes. The LED illuminates and the red reset button pops.Your help would be greatly appreciated. Thanks.
Coldman is offline   Reply With Quote
Old 03-30-2009, 06:40 AM   #2
An old Tradesmen
Rewards Points: 6,548
Is it the same size, angle, and [attern nozzle.
Did you recheck the ignitor gap, and position.
Old 03-30-2009, 12:03 PM   #3
Post
The new nozzzle is the same as the old one, i.e. 1.10, 80deg. A. The gap on the electrodes has not been checked. I don't know what the correct gap is. Thanks
Old 03-30-2009, 02:15 PM   #4
An old Tradesmen
3/16 gap, 5/16 above nozzle center, 1/16 in front of nozzle face.
Since its been a while since it was cleaned and tuned.
You might want to consider having a company come and do that.
Old 03-30-2009, 04:34 PM   #5
Post
Burner will not stay on
Does in front of the nozzle face mean that the gap is offset to the side of the nozzle, rather than being centered over the nozzle? Thanks.
Old 03-30-2009, 04:54 PM   #6
An old Tradesmen
No.
The gap is centered.
Infront of the nozzle means. That the tips are past the face of the nozzle.
Old 03-31-2009, 11:31 AM   #7
Post
I checked the ignitor and the settings correspond to your specs. No change. The burner runs briefly before popping the red reset button. Any other suggestions for fixing the problem? Thanks.
Old 03-31-2009, 12:10 PM   #8
An old Tradesmen
New nozzle may already be plugged.
Pump strainer may need cleaned, and oilf filter cheanged.
Are you sure your not out of oil.
Old 03-31-2009, 12:24 PM   #9
Post
Have plenty of oil. Where is the pump strainer located? Thanks.
Old 03-31-2009, 01:42 PM   #10
An old Tradesmen
Side of pump.
Revove screws. Make sure you turn off oil spply first.
Old 04-01-2009, 01:18 AM   #11
Post
The pump strainer had black particles and black goop blocking much of the screen. I cleaned it thoroughly with CRC Contact Cleaner, dishsoap and carburetor cleaner. Operation has not improved. Could the new nozzle be blocked? If so, can it be cleaned or must it be replaced? Are there any other areas to be checked? When I saw how dirty the strainer was, I thought you had hit the nail on the head. Thanks.
Old 04-01-2009, 06:43 AM   #12
An old Tradesmen
Might want to change the oil filter also.
You must bleed the pump after cleaning the strainer(single pipe system).
And yes, new nozzle could be cogged already also.
Old 04-01-2009, 11:12 PM   #13
Post
Beenthere thanks very much for your help. The burner is fixed! The problem turned out to be an obstruction between the tank and the burner. Compressed air cleared the obstruction.
Tags
beckett afg , honeywell r8184 , oil burner
Lennox Furnace burner won't stay on stevea7777 HVAC 54 01-02-2016 10:38 PM
monitor heater repair help speakers3 HVAC 16 01-18-2015 05:00 AM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
Furnance burner won't stay on. 2007ken HVAC 11 03-04-2008 12:29 AM
