Oil Burner Rumbles On Stut Down. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2008, 06:22 AM   #1
Angry
Oil burner rumbles on stut down.
Ok this oil burner I am working on has about a one second rumble when it shuts off. When I first was called it was trying to explode when it ignited. No brainer ( bad check valve), I put a new pump on it, no more blow back. I put in a new nozzel, and tank filter. Combustion checks close, I will fine tune it when I figure out what is causing the rumble. When I pull the drawer assembly, the nozzle, and the flame retention ring have a little bit of oil on them. What could be causing the oil. I put in the same size, and angle nozzle (1 gal/80 deg.) I think it has the wrong angle nozzle in it, or the wrong retention ring. Anyone got any ideas. Should I try a 90 deg angle on the nozzle. OOPS! its a hot air furnace with a Carlin burner mdl# 100CRD.
RobertS is offline   Reply With Quote
Old 02-02-2008, 06:48 AM   #2
Mainah's Avatar
provide the model of boiler and the burner model, i should have a book for the correct nozzle-
do not go with a 90 deg, that will be wider and more impingment-
**check for a cracked nozzle adaptor too-
Mainah is offline   Reply With Quote
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
radiant burner troubleshooting steve1234 Appliances 1 03-14-2008 01:16 PM
Burner kicks on too much during a heating cycle....need advice JayBird HVAC 4 11-12-2007 08:37 AM
Oil burner won't kick on, have to push reset edski HVAC 4 11-06-2007 02:04 PM
possible to paint behind multi stove burner paddy Painting 1 10-18-2007 07:33 PM
