Oil Burner To Propane Conversion - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 06:49 PM   #1
Question
oil burner to propane conversion
I have an oil fired furnace and I understand that there are retrofit propane burner heads that can be installed. Does anyone out there know manufacturers who make these?
thanks Mike
mikevacarr is offline   Reply With Quote
Old 06-20-2008, 06:47 AM   #2
before you do anything else call your propane company and have them come out and look at it or give them the serial number to check for conversion parts,most will do this for free and even do the change over as part of the hook up service.Don't make the mistake of taking someones word that it can be converted,I did.I now have two non working furnaces and a 30ft long trench in my yard because I was told yes it can be converted.I made the trench for the line,poured a pad for the tank,and disconnected the furnace.then when they came to do the hook up and conversion I was told they don't make the parts for converting my units anymore.Your propane company can tell you just what parts you need,where to get them and if they are available in your area or do they need to be ordered,and who can install them if you need that.
clasact is offline   Reply With Quote
Old 06-20-2008, 07:43 AM   #3
Thanks for the sound advice. As a GC I sometimes get ahead of myself and like superman think I can do anything.
Old 06-20-2008, 07:54 AM   #4
me too thats why I am in the position I am now
Old 06-20-2008, 10:38 PM   #5
When converting, many manufacturers pack the conversion fittings inside the waterheater box before shipping - typically in the instructions package. Make sure you check for the fittings before disposing of the packing materials. Also, I found an interesting website for propane information, address: http://www.localpropaneservice.com
weekendmechanic is offline   Reply With Quote
monitor heater repair help speakers3 HVAC 16 01-18-2015 04:00 AM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
radiant burner troubleshooting steve1234 Appliances 1 03-14-2008 01:16 PM
Propane heating questions Badfish740 General DIY Discussions 1 09-25-2007 07:46 PM
Propane hot water heater philmeister Plumbing 3 04-29-2007 07:20 PM
