Oil Burner Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 11:14 AM   #1
Question
Oil burner problem
Hello,
After cleaning 8 yr old Burnam boiler with Becket AFG burner, flue etc and changing filter, screen and correct nozzle things seemed fine two weeks ago. Now about 50% of time after around 14 seconds or so it sounds like a studdering one to three times but burner keeps going and completes cycle each time. What direction should i be looking at?
bobm202 is offline   Reply With Quote
Old 01-14-2009, 01:30 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,...
It sounds like you need to have a Tech set the combustion ratio with a meter...
monitor heater repair help speakers3 HVAC 16 01-18-2015 04:00 AM
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
